Mikes Web Site
Date:  5-5-2018
Brief Description:  Propellor installation
I can't believe I finally got to select the last new category, "Prop!" Man it sure feels good. Nothing like a propellor to remind you that you are building an airplane! I installed the spinner back plate, then the hub, then the blades and cover. This is a ground adjustable propellor, so I set it to the "climb like a homesick angel" setting :-)))) Once I run the engine I'll set it to achieve a maximum of 2400 static rpm at full throttle. I can not wait to hear this thing run! I've just got to finish wiring in the EFIS so I can monitor all the temps and pressures, and I'll be ready to light it off.
beautiful blade!
beautiful blade!
spinner plate and hub
gorgeous
gorgeous
