I'm starting to see some airplane here! However, I had a few stuggles... turns out the "omega" listed in the manual in the main channel that runs under the cockpit floor and provides support for the lower nose gear attachment point. Why doesn't the manual refer to the part number rather than an obsure reference to the profile shape of the part? Also, I misunderstood the manual and rivet the floor on top of the side pieces rather than underneath... that cost me about 100 rivets to be drilled out and re-pulled!
I also had terrible trouble getting the flanges on the seat longeron to line up with the holes on the cockpit sides. However, this kit is well designed... as things tightened up the holes eventually lined up and all was well. Whew!
