I installed the custom stainless steel exhaust manifolds that Dan Weseman at SPA designed and built for me. No big deal, perfect fit as they snake through the motor mount. Of course I had to polish the tips that will protrude out of the cowl, because... why not?! They will look good against the black belly :-)))
At some point I'll need to fabricate some custom heat muffs for carb heat and cabin heat. At this point in the project, the idea of custom sheet metal work doesn't sound so intimidating, in fact, its kinda fun!
