Michael's Sonex Project
Date:  11-6-2003
Manual Reference:  SNX-T08
Brief Description:  Vertical Stabilizer Work
Finished Riveting the Vertical Stabilizer. Moved on to fitting the fiberglass tail tip. This was a lesson in frustration. The plans call for fitting the fiberglass tip between the tail skin and the upper rib. Trying to get the tip installed caused the rib to bend down. There is no access to the rib and it can't be pulled back up. I plan to investigate the issue on the online Sonex groups to see how other's have address this problem.
