The sub-panel that will hold the Trim knob, Fuel cut-off lever, and eventually the Cabin heat knob was roughly made out of some angle extrusion material. The holes for the components were drilled and the components installed. The sub-panel placement was found for minimal interference and then moiunting holes were drilled. The part was removed, taken home. The part was then shaped with rounded corners, primed and then painted.
