The two wings were installed into the fuselage. After aligning everything, the bolt in the right side was installed. I had difficulty with the left bolt. After examining the bolt, a defect was found, a small defect that prevented it from going into the tight fitting hole. A new bolt was ordered. Will have another go at it once the bolt arrives.
