Michael's Sonex Project
Sonex Tri-Gear
SNX-P13
Cowl Work
After allowing the epoxy to dry 24hrs the excess material was sanded back until a nice tight fit was obtained between the two cowl halves. Additional epoxy was added to the holes on the cowl side to finish filling in the mis-drilled holes.
Cowl Fit
Cowl Fit
Cowl Halve Seam
Sonex Tri-Gear Home
1602
Canopy / Windscreen
Cowl
146
Finish Work
Flight and Tuning
106
Fuselage, Aft
59
106
Fuselage, Forward
123
252
Panel
Propeller
360
Workshop
