Today was fixing areas that needed more material to make the two cowl halves fit better. West System Epoxy was mixed and cotton flox was added until a good consistancy was achieved. First the mis-drilled holes in the bottom and Side were filled. More cotton flox was added to get epoxy mix a little thicker. This mix was added along the top edge where the two cowl halves were not quite meeting. A scrap piece of aluminum was used as a form for the epoxy mix.
