Started cutting holes in the cowl according to the advice given in the Sonex provided Jabiru installation guide. The Prop Hub hole, Cylinder Head Cooling Hole, and Exhaust Exit Hole were located and cut out. The cooling hole for the Oil Cooler was located but will be cut out later.
