The canopy Lexan was removed and the spacing of the fore and aft bows was set to the dimensions in the plans. The canopy Lexan was placed back on the frame and positioned correctly. The two outer side pieces that are part of the side clamp were cleco'd in place. After verifying everything was in place the holes in the canopy to the bows were drilled using a plexiglass drill bit. The corresponding holes in the bows were also drilled. Cleco's were placed in the holes that will not need spacers.
