The alignment of the front canopy bow was again checked and found to be correct. The hole through the Front and Aft canopy bows through the welded angles were drilled. The horizontal support on the aft bow was permanently attached with rivets after deburring. The alignment pin was located, drilled, tapped and installed. During the alignment pin installation the alignment hole was drilled.
