Michael's Sonex Project
Sonex Tri-Gear
SNX-G01
Installed Thottle in Cockpit
The AeroConversion Throttle quadrant was installed on the pilot side fuselage. The throttle was located and the mounting holes were drilled to size, deburred and then two AN3-5A bolts were installed to complete the install.
Throttle Mounted
Sonex Tri-Gear Home
1602
Canopy / Windscreen
Cowl
146
Finish Work
Flight and Tuning
106
Fuselage, Aft
59
106
Fuselage, Forward
123
252
Panel
Propeller
360
Workshop
