Used an engine hoist to help in the engine installation. Installed aft shock rubber mounts on the engine mount and then put the engine in place. Installed bottom engine bolts first and then the top bolts were installed. All four bolts were torqued to the correctly value. The two exhaust pipes were installed and an interference problem was found with the front landing gear. I've sent an email to Sonex asking for suggestions. The engine was checked for correct placement and it was spot on! I guess all the time I spent getting the engine mount just right was time well spent.
