The magnetometer needed to be mounted somewhere in the aft fuselage area under the turtledeck. I found a good spot behind th second former in from the cockpit. After taking a lot of measurements a bracket was crafted as shown in the pictures. It was then located in the aft fuselage and drilled in placed using the pre-drilled holes in the bracket as guides. A small support bracket still needs to be crafted for additional support.
