Brief Description: Auto Pilot Servo and Fuse Blocks
The pitch autopilot servo was installed onto the new bracket. The bracket was then installed into the fuselage and all control rods were reconnected. This completes the redesign of the pitch autopilot servo placement due to interference. Next the two fuseblocks were installed into the right forward fuselage. The large fuseblock is the primary fuseblock and the small fuseblock is going to be used for the avionics. These fuseblock were bought from from a boating supply shop and both include integrated ground blocks and clear plastic covers. I also powered up the panel and played a little.
