Brief Description: Right Aft Fuselage Skin and Longerons
The left aft fuselage skin with longerons cleco'd on was moved off the work bench. The right aft fuselage skin was moved onto the workbench. The upper and lower longerons were clamped in place drilled and cleco'd. The rudder stop was attached to the outside, drilled and then cleco'd.
