Brief Description: Attaching Left Longerons to Side Skins
The upper and lower aft fuselage longerons were attached to the left side fuselage skin with clamps. The longerons were then pre-drilled using the holes in the skins as guides. As the longerons drilled cleco's were installed. The Rudder Stop was installed at this time as well.
