One Aileron Wing skin was predrilled at the required locations. The Ribs were then installed, drilled and cleco'd. The Aileron Tip Rib (SNX-W04-10) was place, but didn't seem to fit correctly. The Aileron Skins were re-check and found to be correct. The Tip rig will need to be checked next to verify shape and size.
