Brief Description: Panel Mount Points and Support Angles
Four nut plates were added to the side support angles. The nut plates were located using holes previously drilled through the panel and support angles. Next the instrument support angles were attached to the panel. Countersinks were put in the holes in the angles, and the panel was dimpled. Finally the angles were placed and flush rivets were installed.
