Michael's Sonex Project
Sonex Tri-Gear
SNX-L01
Installed Axle Weld Bolt
After checking fit of the required bolt on the first axle welded part, I had to ream the holes in both the welded part and titanium gear leg to get the proper fit. Once done the bolt was installed along with the brake cable redirector.
Sonex Tri-Gear Home
1602
Canopy / Windscreen
Cowl
146
Finish Work
Flight and Tuning
106
Fuselage, Aft
59
106
Fuselage, Forward
123
252
Panel
Propeller
360
Workshop
