Brief Description: Drill to final size all holes attaching HS-801PP s
Drill to final size or match drill all the remaining holes attaching the HS-801PP skin. The suggested drilling sequence begins at the intersection of the HS-708 center rib and the rear spar and proceeds both up along the rib and outward toward the tip. Put clecos in every second or third hole as you drill them.
