Today I installed gold prop hub to flywheel using AN3-10 bolt and lock nuts. I was missing 1 nut so I changed them all out to be the same.
Before installing flywheel assemby to hybid studs/ safety shaft be sure no Loctite is left on the face of the 5th bearing. This will keep prop hub from seating properly.
Next installed flywheel assembly on to safety shaft/ hybid studs, Torque hybid stud nuts to 25 ft-lbs and alum safety shaft to100 ft-lbs. Retorque hybid studs to 25 ft-lbs.
