Barracuda
Barracuda
Ailerons
3-12-2008
prep for finish at hinge points
400 grit - to inside hinge areas prep for urethane primer - two full wet coats to all hinge locations
Barracuda Home
1856
Ailerons
Center section
138
477
242
529
Hardware
Metal Block 1
Metal Block 1 - open
Metal Block 2
Metal Block 2 open i
Metal Block 3
Tech councilor / ins
wing outer panels
83
272
