Barracuda
Barracuda
wing outer panels
11-3-2007
RT outer panel
line sanding prep for skinning
laminated 2 more 1/16 birch bows on the right wing tip to bring the thickness up to 3/16 the tip rib is 1/4 , with the laminations and glue the bow is about 1/32 under the tip width - the leading edge fairing will make up the differance.
general rt wing clean up for skinning .
Barracuda Home
1856
Ailerons
Center section
138
477
242
529
Hardware
Metal Block 1
Metal Block 1 - open
Metal Block 2
Metal Block 2 open i
Metal Block 3
Tech councilor / ins
wing outer panels
83
272
