Barracuda
Barracuda
wing outer panels
10-30-2007
hinge blocks / rear spar attach
made and glued in all hard point mahogony blocks for the outer panel (s) aileron hinges and rear spar straps. Also made and glued the curved end rib block for the skin at rib 9.
Barracuda Home
1856
Ailerons
Center section
138
477
242
529
Hardware
Metal Block 1
Metal Block 1 - open
Metal Block 2
Metal Block 2 open i
Metal Block 3
Tech councilor / ins
wing outer panels
83
272
