Barracuda
Date:  6-1-2007
Manual Reference:  Ribs 1-9
Brief Description:  Rib construction
Wood finaly arrived !! Took inventory / seperated stock to plan sheets.
Cut and loaded first master rib . Need to scale and cut first master set of Gussets from 1.5 mm ply.
Concerns - I have reservations about pulling the ribs from the jig ! All the info I've found on rib jigs is about the same type set up. Im not concerend about the epoxy adhering the rib to the jig. I just dont think its going to slip right out of that jig without some finess.
Bigger concern - my wifes going to be looking for her waxpaper and sandwich wrap !
gusset tracing on ply
gusset material
gusset material
