Barracuda
Date:  4-6-2007
Number of Hours:  3.00
Manual Reference:  bracket at stn 234
Brief Description:  pulley and horn control breacket at stn 234
angain simple and straight forward - until your wife calls you for dinner - I had jigged up and trued the horn assembly for welding when I got the call "HONEY" - as all builders know you cannot in anyway hesitate between wife and project - that leads to big delays. Anyway as I turned off the tig
i noticed and made a mental note to recheck my horn placement on the center tube - its ofset to one side - and of course upon returning to the piece "I HAD FORGOT" and welded it left instead of right.
When I recovered from the gray out - I noticed that the offset was to keep the control rod end on centerline with the elevator horn - simple correction - do the same to the elevator horn .
