Barracuda
Barracuda
LT aileron
added lead ballast right at 5lbs , to rear of nose spar as done on right aileron . T-88 and micro were used to secure the ballast . Bolts , washers and lock nuts were also used.
19 .20 Ounces per typical
Barracuda Home
1856
Ailerons
Center section
138
477
242
529
Hardware
Metal Block 1
Metal Block 1 - open
Metal Block 2
Metal Block 2 open i
Metal Block 3
Tech councilor / ins
wing outer panels
83
272
