Set the entire assembly up on jack screws - preparing for closing . Called a local EAA Tech councelor for inspection after osh. I will add additional jack screws to the elevator and shoot each point with the lazer prior to closing skins being glued. The tolerance for twist in 1/8 inch or less over the span . The lazer is accurate to 1/32 at 100 feet .
