Brief Description: Re-designed Root Rib per Jim Stanton's comments
Re-designed Root Rib per Jim Stanton's comments - "Root rib upper curve from mid-chord aft should perfectly match main ribs"
SolidWorks: - copied main rib sketch - overlaid root rib sketch on top to use identical main rib geometry - 2" spacing lines per Jim C's drawing - smoothed upper spline curve - used same vertical stick locations - revised diagonals to intersect at junctions - doubled rear verticals at main spar per Jim Stanton's suggestion to allow for wing attach fitting cut-out & retain strength - plan on solid nose block per Stanton's manual
