Brief Description: Trimmed Ribs#14-20 with router pattern bit
Trimmed Ribs#14-20 with router pattern bit - used tywraps to hold rib & Master Rib together in position * gussets provide space underneath for tywrap - scotch tape under rear spar stub to keep from dripping through
* Need to go S-L-O-W-L-Y to prevent gouging capstrips * Should've thought about orienting grain on capstrips for later router cutting (some are cutting against the grain)
