Brief Description: Longerons located in place (10-10)
Completed the bulkhead brace, bell crank rib angles and the spacer for the aft deck. The bell crank rib angles required countersinks and to match drill some of the holes I had to use the angle drill s. I also slid the longerons into place, which fit in nicely.
