Brief Description: Rivet front spars to skins (9-13)
Trying to catch up the log here a little. I completed attaching the front spar to the ribs and then to the skin. Per the instructions I left out the end rivets to allow access in the next few steps. There’s a little bump in the skin where the skin meets up with the rear spar and the inboard rib. Maybe I didn’t have the angle perfect in that location…build on. I was able to use the squeezer on the front spar rivets.
Slight bump in transition from rib to rear spar (22-157)
