While I wait for the trail edge to set up, its back to work on the HS. I skipped this step earlier so I could get some primer on the bearing flange. I made sure to tape over the bearing and seal. I used the AN3-5A bolts into the spar assembly to secure the bearing assembly and hold the flanges flat as I riveted it together. This worked well and is now complete. I also started deburring the thick stiffeners which is taking a while. Basically, I work on it until my hands get tired, then take a break. 4 out of 6 ready for priming.
Bearing assembly clamped and clecoed in place (21-063)
Bolts holding flanges flat and keeping the holes lined up (21-065)
