Brief Description: Clean and Prime Right Wing Lower Skin
I layed the right wing outboard lower skin W-705-R on a piece of plywood sitting on 2 saw horses. Using a red Scotch-Brite pad I scuffed the wing rib and spar contact area and cleaned with Lacquer Thinner. I sprayed the area with self-etching gray primer. While the primer was drying I did the same process to the wing rib flanges and let dry.
