I received the 5 wire Teflon trim servo wire and now I had to figure out how to run it from thr tail to the instrument panel. Looking at the inside of the fuselage, I noticed each bulkhead had a small hole at the bottom center. I decided to use these holes to run the cable up to the baggage compartment bulkhead. The Heyco SB250-2 snap bushing fit the cable perfectly and would require enlarging the bulkhead holes to 1/4". I did this and deburred the 4 holes I enlarged. I installed the 4 snap bushings. Next I pulled the cable through starting at the tail and moved forward. The remaining cable forward of the baggage compartment bulkhead will be bundled with other cables later and run to the instrument panel. I also ordered Click Bond wire tie pads that I will bond to the fuselage skin to secure the cable from moving between the bulkheads.
