Time to mount the high pressure fuel pump and filter to the F-7115A bottom cover. First I cut the rubber channel to 4 equal lengths and using weatherstrip adhesive I glued the strips to the cover flanges. While the adhesive dried I pulled the pump and filter from inventory and the two stainless hose clamps that would hold the pump and filter in place. Once the adhesive was dry I mounted the pump to the flanges and wrapped the clamp around the pump and under the flanges. I tightened the clamp and did the same thing with the filter making sure the flow arrow was in the correct direction. Tomorrow I will fabricate the fuel line from the pump to the filter as shown in drawing OP-21.
