MARK'S WEB SITE
Date:  11-11-2011
Number of Hours:  1.10
Manual Reference:  DWG 4
Brief Description:  Elevator Trim Motor Assembly
I decided to clean up the shop today and also clean up a loose end. Months earlier I had primed the E-616PP left elevator trim cover and the two EET-602B z channels. Now was a good time to rivet the z channels to the cover and install the left elevator trim servo motor. I clecoed the channels to the trim cover and using my pneumatic squeezer I set the 6 AN426AD3-3.5 rivets. I placed the trim servo motor on the z channels and installed the 4 MS35206-215 screws as called for in DWG 4. I placed the unit in the servo box and stored it for later installation into the left elevator.
Trim Cover Rivets Installed
Servo Motor Installed
