Drilled the F-804 center spar carry through. Finished all the bottom skins including the rear baggage floor parts.
Fit the rear deckand associated spacer plates and match drilled.
Drilled the F-816 L/R canopy rails.
I was a bit surprised when the plans called for me to use a cargo strap to pull the landing gear towers into alignment but it worked. Drilled the gear tower/longeron holes.
Installed the seat back support plate and seat back support in preparation for drilling.
