BushCaddy ELSA
Date:  9-2-2008
Number of Hours:  1.50
Manual Reference:  Stewart Systems
Brief Description:  Fuselage primed
I used two quarts of Stewart Systems one-part primer/sealer. I think I figured out my spray gun. The primer went n great and is very smooth. Now if it works like that for the color I will be very happy. Doing the bottom was a challenge let me tell you. I coated it first and will also do the bottom first with the Santa Fe Burgundy then the sides. Talked to Stewart Systems and that is how they suggest doing it and it sounds good to me. Tomorrow I will do the Yellow on top as pictured on my title page. The fun part is going to lay it out with the lines. I have two static vents one on each side of the fuselage and I used a round tooth pick to keep the paint out. They should be in the yellow part of the paint scheme. Yellow is defiantly a hard color to paint with as I have found out but I would do it again as I like the visibility it has.
We have white primer
ROund tooth pick keps the hole open
Cargo Door in place for color lines
