Brief Description: worked on horizontal, rudder, panel and avionics
Today I installed the horizontal stabilizers and rudder. I cut out for the GRT Glass panel, power switches, ignition key and start button. I ordered my N numbers from aircraft spruce and received them Friday. I had to see them on so I cleaned the vertical stabilizer good and applied them. One thing on the N numbers if you order them through aircraft spruce only order one not two like I did. When I received them I have two sets of N620MP. That’s right when you order one you get a set, it dose not say that in the catalog so I thought I had to order two. The two pictures of the paint is a a good representation of the color of the airplane. For some reason when I take the picture outside the digital camera turns it red.
