BushCaddy ELSA
Date:  4-18-2007
Number of Hours:  1.50
Manual Reference:  Section C
Brief Description:  Mounted rudder on vertical stabilizer
Mounted rudder on vertical stabilizer and installed PC-065 and PC-066 on each side of the rudder using 414 rivets in the PC-66 to rudder and bolts specified in the drawing.
Pulled elevator parts from shelf and started prepping for installation by cleaning all surfaces and roughing up with a green pad and priming one set with zinc chromate.
