Brief Description: Cowling top and engine hatches.
Cleaned and used a green pad to ruff up the aluminum and primed all the cowling top parts. I am working on my spray booth out side to get it set up for painting the plane also while the parts dry. Clecoed and riveted the cowling aluminum top parts and engine covers. Re-assembled the top cowling and cut out for the engine oil door and installed hinge and side supports. Laid up some fiber glass on plastic to make the front support and will order a hatch lock from aircraft spruce.
