Brief Description: Fiberglass work on the engine cowl.
More sanding and cutting down the air scoops to fit the Chevy installation. Bill has the upper cowl and I have the bottom cowl. Hmm...how come I get the dust to fall on me job? I did replace the main fuel line from the fuel flow sender to the engine with starlite hose. The original hose was too stiff and may have cracked a fitting eventually due to vibration between the engine and the firewall.
