Final drilled and deburred wing locker lid (left wing)
Cut hole in left wing fuel tank for top mounted fuel sender. Ok, you wouldn't think this would take quite so long, but it did. I started with the fly cutter using my cordless drill. The tank isn't flat on top, therefore this was dicey at best. I prefered the handheld at this point because if the cutter blade would catch, the spin would stop.
