LANCE'S WEB SITE
Date:  6-26-2023
Number of Hours:  3.00
Brief Description:  t wing fuel lines installed
Installed fuel lines with EZ Turn fuel lube. The line holes that led to the tank (rib 3) needed expanded UP just a bit in order to make it easier for a deep socket to fit on it. Required to remove the tank (pretty lodged in there) and clean up after the cut expansion.
