Made Rt Wing fuel sender jig. Decided to use a lightening hole for the main hole size. After making the jig I fastened the leading edge back down (cleco'd) with all leading edge ribs in place and started drilling the holes for both the sender and the fuel filler. Note: The piece that I cut from for the jig was a failed (screwed up) end rib from the left wing tip.
