Brief Description: Rt Wing Lower Skin final drill and start leading e
Final drilled all rt wing lower skin (not front or rear spar yet). Lined up lower side leading edge. Drew 10mm edge distance line along the length on the leading edge bottom rear side, slid it under the lower skin edge until i could see the line through all of the pilot holes that is on the front spar edge of the lower skin. Drilled and cleco'd every other hole (#40)
