Brief Description: Right Wing final rivet rear ribs (main and rear sp
Final riveted rear ribs, both front and rear spar. Torqued AN3 (20 in.lb. to 25 in.lb + 12-15 in.lb. friction/drag torque = 34 in.lbs.) and AN4 (50 in.lbs to 70 in.lbs. + 12-15 in.lbs = 64 in.lbs.) bolts on main spar plate and applied torque marker.
