Brief Description: Right Wing scotchbrite and cortec
Gosh I love this Paasche Airbrush. I disassembled the entire wing, scotchbrited the joint parts, wiped everything down with acetone, then used the airbrush (set at 30psi with maybe 20% water) to spray cortec on the lot. Drilled and riveted the bellcrank. Ready for the topskin.
